Gdetrailer
Nov 26, 2015Explorer III
Trashwagon wrote:
Took the coach out today to scale it. 25 miles to truck stop and back. Ran like a top till I stopped at a light about 1/1 mile from the house. Pulled out and had no power ad was spitting and popping. seemed like it was stuck in high gear but no. runs and idles ok at low rpm but at full throttle it pops through exhaust...... Triton V-10 any suggestions as I'm illiterate when it comes to the big gassers with all the tech on them.
Most likely a bad COP (Coil over plug)..
The problem is you have 10 of them and you will need one known good one to swap out one at a time to find the bad on.
You could try a code reader to see if it has any pending misfire codes which might help narrow down to one side (bad COPs often do not set the check engine light but may be detected as a misfire or multiple misfire).
If you search for the model year of the engine on Amazon you can find generic COPs real cheap (8 for $50..). Use a generic COPs to trouble shoot ONLY and when you find the bad COP buy a NEW MOTORCRAFT COP from Amazon for $50 (IE do not leave the cheap generic coil in place, they do not last).
Much cheaper than going to a Ford dealer.. They will get you for $100 per COP plus labor.. or about $2K..
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
