Gdetrailer
Dec 03, 2015Explorer III
Trashwagon wrote:
Well it seems that, and they are experienced with these modular engines, they can't find anything wrong. They have been driving it each day and it runs fine. No codes show for anything. guess I got a "gremlin" hiding in there, eh?....... So have "roadside" on the insurance policy and thinking of gettin Good Sam Roadside too.
Yep, that IS one of the signs of a bad COP..
They tend to be rather intermittent.. until they finally fail..
IT WILL BE BACK (think of the Terminator voice)..
However.. IF you have never changed the plugs (and never pulled the COPs) the Rubber BOOTs that fit under the COPS could be going bad and cracking.. This would allow some moisture in the air to cause intermittent misfires..
Typically when you replace a COP you replace the boot..
As I mentioned before COPS do not always set a check engine light, in fact I have never had a bad COP set any lights even though the engine severely lost power and was skipping badly..
What you do want to check though is for PENDING CODES.. Those are codes which the engine computer will record if anything goes out of range.. In your case the skipping if it reoccurs a few times and long enough the engine computer should record a pending code for misfires or multiple miss fires.. When it does that you will get a bank 1 or bank 2 misfire code.. That helps you to determine what side..
I would highly recommend you get a code reader, you can get a $100 reader from Harbor Freight (You can use a 20%off coupon and get it for about $80) which can read engine codes..
My reader has saved me thousands of dollars in repairs over the last several years.. Just recently had one of the Oxy upstream (front) sensors go bad.. Replaced the bad one for $30 from Autozone.. Fixed the light.. I decide to change the other front one since it would be not long before it fails..
Total fix $60 for sensors and about an hr worth of my labor.. That would have cost me $90 per sensor at a Ford dealer PLUS a diagnostic fee of $125 (for their code reader hookup) PLUS at least 4hrs min at $120 per hr.. They would have only changed one and waited until they could get me again for the next one too boot.
So the dealer would have charged me somewhere around $695..
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
