bearsnob
Feb 12, 2017Explorer
Was looking to see what the real shear bolts looked like and ran across this post from 2011: http://www.5thwheelforums.com/forums/archive/index.php/t-2061.html
Looks like the same problem only the track jumped because of worn out parts in the pinion assembly. It would be a huge coincidence if mine had worn out parts. Looks like I have some more investigating to do before I try to remove the bolts they put in there. Definitely the wrong bolts because the right ones are threaded the entire length, have an allen wrench head, and are either 1 or 1.25 inches long. These have hex heads, are only threaded about half the length, and are about 2.5 inches long. **** it keystone. It's like a $2 part and instead you pound in something else you have laying around. The idiot probably dropped them on the floor and was too lazy to go back and look. I wonder if the right ones are installed on the opposite slide.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
