D_E_Bishop's avatar
D_E_Bishop
Slide creeps in, not out.
Earlier this year our HWH pump died and we had a Mobil Tech in Oregon replace it for us. Now the slide is creeping in about two inches.
The hydraulic lines were not opened and only the pump motor was replaced. I did have to crank the slide in by hand, something I would gladly pay to have done if another failure occurs.
I read somewhere in the HWH literature that the system was self bleeding, I can't find any info on bleeding the system.
Any ideas?
Update of sorts from 11-14, I have a limited education in hydraulics and I am not criticizing anyone's answer but I just don't understand how there can be pressure in a hydraulic system when the pump is off. Okay, with a check valve in place and when a system is pressurized there will be some static(I believe that's the right word) energy in the system but isn't it expended as soon as the system is operated with the pump off? My understanding is that a liquid(hydraulic oil in this case) cannot be compressed so, shouldn't even an itty bitty leak release the static energy instantly? How can there be enough energy to move my dinette/sofa slide 2 to 4 inches?
I truly do not understand.
  • Replacing the pump motor would not cause your problem. Yes, HWH systems are self bleeding. Just extend and retract 4 or 5 times and that will remove any air. Replacing the Pump Motor would not cause air in the system. Creeping out or in with no visible leaks is one of the extend or retract solenoids. They are leaking internally. You can manually open both extend and retract and run the room for 15 to 30 seconds and if there is any trash on the needle valve , that usually removes it. If not you replace the retract valve. Doug
  • donn0128 wrote:
    You have a bad check valve which is part of the valve. Replace it.
    agreed. we had hydraulic slides and jacks on a previous motorhome. for each slide and pair of jacks there were two solenoid valves.. in/out and up/down. you likely have a leaky "out" valve on your slide.
  • You have a bad check valve which is part of the valve. Replace it.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 12, 2025
