fulltime5er's avatar
fulltime5er
Slide issue
We have a 2014 Cedar Creek 36CKTS. Parked it a month ago, went out today to get ready for a trip next week. Ran the slides out and did some work. Went to put the slides back in, and the dining slide only the back starts to come in, which angles the slide. I stopped and tried several times with the same result. The side by the door does not move. Nothing appears to be blocking it. Any suggestions?
  • Could it possibly be a schwintek system and needs to be reset or synchronized because of possibly letting off the control while in motion? Does it have gear like aluminum tracks on top and bottom of slide, outside?
    Aluminum tracks would be on the front and rear slide walls.
    Do your operating instructions say "Hold the button for 10 seconds after going all the way in or out" ?
  • Where would I look for this shear pin? Would it be visible without taking the cloroplast off the bottom?
  • I had a similar experience with a Cardinal fifth wheel. One side of the slide hydraulic has the "power" and the other side of the slide is moved by a bar going over to the other non powered side. There is a pin or bolt in the bar on the non powered side that can get loose or break. I have explained this in "layman's" terms since not a mechanic. Look under the slide for the bar and check to see if bolt or pin is still there. If the bolt is missing, the non powered side will not go out. I think the bolt is a number 8 and readily available at hardware stores. Now, this may not be your problem but is the first thing to check. Also, you may have a different system such as electric/cable. If this bolt is your problem, you will have to get the slide even. Front jacks worked the same way on the Cardinal and the bolt came loose and fell out and that jack didn't go up or down. Someone with more mechanical knowledge should come along for a more precise answer.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
