Had slide checked for squareness, etc. then installed guardian plates on the underside. Took it this AM to have tires checked and the slide had moved out about 1/2in or less. it is the Rear slide...R...
Thanks... I will check that Couple of questions..will it travel ok like that or not? Where would the lever be? I can get to motor fine, but not sure where lever would be? Since it stays tight at top seems like a brake kinda issue...but that is coming from me a rank novice in most things mechanical
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
