2oldman
Mar 29, 2018Explorer II
the bear II wrote:Yes, check there first. I believe I have a thermal-limiter switch too which will halt the slide if the motor is working too hard. It will reset in a few seconds. Sounds like that's not Op's problem.
Usually it was a very tiny circuit breaker had tripped. My circuit breaker is located near the control unit for the slide which is near the battery compartment and fuse panel.
Anyway, if you can find that circuit board, see if you can bypass it with a short wire just to determine if the motor is still ok.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
