randydykes's avatar
randydykes
Slide needs adjusting
Has anyone ever had to adjust the slide on a tt? With the slide out and being on the inside of the trailer we have about an 1" difference at the top. What I mean is if you measure the wall to the slide it's about an 1" more at the top than it is about the bottom. It's a used tt our son picked up so just trying to help him get it redone.
Thanks for the input.
  • if it seals good all the way in and all the way out then you probably only have the usual poor quality workmanship of an rv.
  • If one side/edge is not pulling all the way in flush, then yes something is wrong
    But we need info to help
    At the very least the make, model, and year of trailer
    Even better will be info about the type of slide mechanism
    Hydraulic, electric motor, gear driven, screw driven etc..
  • the difference is side to side not top to bottom. I am going to try and get a picture posted
  • If you mean the top edge sticks in 1 inch further than the bottom when fully retracted
    I think you will find its made that way
    Go outside and look at it closely
    Are the top and bottom flush with exterior wall of the TT, so it doesn't leak when closed
    Or does the bottom stick out 1 inch
    Or is the to edge bent out letting the top set further in?
  • You might post a picture, I'm not sure if I understand your description of the problem. Or at least a model number.
    Some slides are completely adjustable, some are partially, and I have one right now that isn't adjustable. To change how it closed would require relocating the bolts holding it.
  • You need to figure out which brand and type of slide out you have.
    In wall? hydraulic ? Electric ? which manufacturer (of the mechanism not the coach)
    Once you find out, Youtube can be very helpful. It was for us.
  • Maybe something HERE will help.
    Many different slideouts......cable, electric, hydraulic, in wall/thru frame etc.
