judelaurenzo25g
Apr 04, 2014Explorer
Chris Bryant wrote:Ive done both connected and unconnected leads but I ground out on the frame so anything is possible.
Are you testing for voltage under load, or just the unconnected leads? Are you testing between the leads, or from the leads to ground? These simply switch the polarity to reverse, so the ground could be bad if you are testing to ground, and not between leads. Likewise, a bad connection can show voltage under no load.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
