judelaurenzo25g's avatar
Apr 04, 2014
Slide not working...Why?
I have a friend who is having issues with his slide on a 2001 fleetwood wilderness (trailer). It just simply stopped working. We checked everything. Fuse, switch and motor. Here is the part that is stumping me, when testing the wiring at the motor with a light tester, we hit the switch and we get power going in and out but no movement on the slide. We take those some wires cut them and put them direct to a battery and the slide moves in and out. The house batteries are fully charged so thats not the problem.
How does the ground work on these motors? What determines the ground on motor when the switch is pressed, the frame?
Does anyone have any suggestions to what the problem can be?
Thanks in advance,
  • i'm a simple things first kind of guy. do the jacks work? other slides work? check the hydraulic fluid reservoir and be sure that it's not empty or low. start the engine and they try...might be the battery is low and needs the extra voltage from the alternator/charger to pop open the slide.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
