Smitky's avatar
Smitky
Slide not working
I have a 2009 31ft Winnebago Chalet (Access). Last night I went to close the slides. Our back one worked fine, but the front one did not. What is strange is there is no lights (green or red) on the switch/panel. Everything else is working (other slide, test switch for levels etc...) I replaced both 40 amp breakers, even though they had not popped. I switched the back and front switch and was able to activate the back slide. This tells me it is not the switch. It seems if it was the motor I would get some flashing code. I have reset the panel/switch. Any advise appreciated. Suppose to be touring Lake Superior starting on Saturday and would rather not have to hand crank the slide.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
