hotjag1
Mar 18, 2021Explorer II
dougrainer wrote:hotjag1 wrote:
I've had this happen a couple of times on my "electric" slides. Both times, for an unknown reason, the brake lever on the motor had moved to the lock position. This lever is on the back of the motor and it will slide about a 1/4 inch to one side if pushed firmly. This unlocked the motor both times and the slide worked normally after that. After I ran the slide in and out a couple of times, I put the brake lever back into the original position. Otherwise, the slide would move out freely on its own. I hope I explained that right.
You have it backwards. The LOCK TAB is supposed to be in the LOCK position. You UNLOCK the TAB to get the motor free to manually move the room or motor. If you have it in the UNLOCK position the motor is "free" and the room will creep out from fully retracted. Doug
You are correct Doug...I figured that I didn't explain it correctly:D
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
