jwchenault's avatar
jwchenault
Slide Out Clutch?
My unit is nearing the expiration of the warranty period and I have noticed that when I run the slide in or out the clutch on the drive mechanism seems to slip prematurely, often requiring someone to push on the dinette in order for the gasket to pull up tight at the bottom on the way out and also someone outside pushing on the slide in order to get it moving on the way in is this normal or is it something I need to have looked at while warranty is in force?
  • It is not normal.
    You should only have to touch the button. Get it corrected before warranty expires.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
