gmgExplorerMay 20, 2015Slide out failureWe have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving norma...Show More
ChandalenExplorerMay 20, 2015Does the manual override work?If not, you need hydraulic fluid. Add a little at a time because when they retract the fluid goes back in the canister. In other words... don't top it off when the slides are out. Don't ask how I know this.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentSlide failures?Schwintek Slide Failure :(Schwintek slide out system failure - brand new TTRam Cummins/Aisin FailuresWater Pump Failure Traveling To The Eclipse
