We have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving norma...
Thanks Chandelan. Fluid level is fine. I suspect something electrical because the electric pump either runs or it doesn't. While it is running the slide is moving. Problem is it won't keep running even when the rocker switch is continuously depressed. After waiting a few seconds it will start up again momentarily then stops abruptly again.
