We have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving norma...
Check the wires from batt to the pump. Are they secured and tight?
My pump has a button on it as well as the inside one. Does the pump stop of you use that button (if you have it)
I'm unsure about all hydraulic slides, but mine will keep pushing as long as the button is pressed. However, the fuse will blow after about 5 seconds of holding it when the slides are all out.
