We have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving norma...
Chandalen, I already checked the wire connections at the pump for tightness. I don't remember seeing a switch right at the motor but will check. That would be a good way to prove the inside switch. Thanks for the tip.
