We have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving norma...
MOST systems like you have, they have a auto reset 12 volt circuit breaker supplying the Pump assbly. IF the battery is low or weak, the Power Converter has a hard time supplying the needed amperage to run the Pump motor under load. FIND the 12 volt breaker/fuse that supplies your pump. Odds are it is weak, or you can bypass it to test if it IS weak or is tripping due to 12 volt power supply problems. LCI(Lippert) systems are especially prone to this type problem. Doug
