joshuajim's avatar
joshuajim
Explorer II
Aug 31, 2015
Slide out fuse - SOLVED
I was reading another thread about a person blowing slide out fuses. Not wanting to hijack it, I have another power issue.
I was thinking that I have never seen a fuse for my slide on my 2011 Wildwood. I checked to see if there was a fuse at the battery - nope. Checked for a fuse at the slide motor - nope. Followed the blue and white wire from the motor and it goes to the power panel located in the kitchen. Nothing but 15 amp fuses and two 40 amp fuses. I pulled them all and the slide still works.
I pulled the power panel and found the blue and white wires connected to a black and white set that seems to come from the power panel. It's hard to see exactly where the wires are connected as the panel will only come part way out of the cabinet.
Is it possible that there is no fuse for the slide? Seems dangerous.
  • The 15A fuses are for individual DC circuits.....lights, fridge, water pump, water heater and the 40A fuses are 'reverse polarity' fuses. They protect converter from batteries being installed backwards.
    Slide out (tongue jack, landing gear, stabilizers) are wired directly from battery and have in-line protection either from Fuse (in a holder) or via a DC Circuit Breaker (auto or manual resetting).
    Trace wiring from battery......
