FootSoldier wrote:
downtheroad wrote:
OK, pictures help. What I see has nothing to do with the slide locks that you use inside.
It looks to be separating Eternabond Tape.
Solution:
- Dicor Self Leveling Sealant or
- A new strip of Eternabond Tape over the top of the wrinkles.
Well, I think the mystery is solved. When I put the slide locks in place I didn't position them up above on the wall, I let them rest on top of the slide roof. The subtle side to side movement going down the road with the bottom edge of the slide lock resting on the roof seam apparently caused the wrinkle. My bad.
Now, I feel like I have to do something about it and I am leaning toward a small Eternabond patch over the wrinkle. I think that would be the most flat I could make it?
Any thoughts?
Thanks.
Yikes! our 23SS had stickers on the wall, above the slide, showing where to place the locks. did they stop putting them up there?
i'd go with the Eternabond solution.
