Sixpack_Jesus
May 20, 2014Explorer
mobilefleet wrote:
me thinks the plastic gear in your slide motor is stripped, if you don't see a shear pin broken like the others suggest. Easy fix, gear kit can be bought from venture mfg
If the shear pin is the t shaped pin that goes into the notches than the motor is able to spin that.
