Rgtopda's avatar
Rgtopda
Slide out motor
I have a 2006 Fleetwood Excursion. The middle slide motor is broke and I need the replacement motor. The part number is #130-1204. I cannot find replacement number...and they can range from 399 to 900 dollars.. any help would be appreciated
  • I have an older Fleetwood does yours have the accu-slide that runs by cables.
    Jay D.
  • Power gear is the name on the plate but they were bought by someone else. All other numbers are gone . That was the reason for the item number only. Just hoping it sounded familiar to some techs
  • Does the name plate mention any other manufacturer? I'm sure Fleetwood does not have it's own motor factory so they bought them from someone. You may be able to take the bad one to a local RV parts dept. and they will be able to ID a replacement. That worked for me.
  • I forgot to mention it is a power gear motor that is no longer made by them
Having RV issues? Connect with others who have been in your shoes.24,304 PostsLatest Activity: Aug 24, 2025
