Chandalen's avatar
Chandalen
Slide out problem
I assume this was caused by my slide out pulling in too far, please correct me if I'm incorrect on that:
The slides pulled in... and the wall pulled up higher.. about 3" off the ground... and the floor of the slide was still on the floor.
I see six screws poking up at random directions and placement that obviously went into the wall that is noe 3" higher than it should be.
Outside, the top of the slide did not fully close by about 2", but after I drove to the dump site it was closed flush against the camper.
My plan was to put the slide out, unscrew the screws, then make new pilot holes, put some gorillia wood glue in them, and drive in the same screws I pulled out (for correct size).
So: Is this going to work (in theory)
and
Was this a just happens moment, or is the slide pulling in too far?
1 Reply
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
