dougrainer
Oct 17, 2019Nomad
To keep the slide seals from adhering to the slide. Rubber seals/gaskets can "bond" and then tear loose. Also, to make the mechanism work a few times. If NOT using the RV leave the rooms retracted. IF the slides fail to retract, HOW do you get the RV in for service? Better to have the slides fail retracted. Doug
