When I park my Suncruiser Itsca , I store indoors in Arizona and disconnect batteries ,when I return the one slide out is sticking out and jammed on the locks,cannot bring in or out ???wondering if an...
If you have the HWH slide system, IF either the retract solenoid or the extend solenoid leaks fluid internally, the room will pooch out a few inches. Manually open the extend and retract solenoids a few times to help flush out any debris. Then retest. IF the room continues to seep out and there are NO visible fluid leaks, replace both solenoids. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
