- UsnthedogExplorerThanks for the responses. Decided to just replace the trailer. I'm not monitoring this post anymore but if someone wants to jump on and continue it, go for.
Jeff - MFLNomad II
Usnthedog wrote:
MFL. I have replaced the D seals, but I need all the rest. I'm under the impression that the slides must be removed to replace the wipers and seals.
While I've not replaced wipers on mine, I can see they would be more difficult, especially the inside top. I don't think mine would require slide removal, but would have to be partly extended to reach.
Jerry - bobsallyhExplorer III replaced mine. It is "P" seal. Not hard, but sort of labor intensive. The hardest part was removing the old adhesive. Also, there are many different configuration of seals. Most slides don't need to be removed. https://uni-grip.com/
https://www.cleanseal.com/
http://parkin-acc.com/page39.html
https://www.pellandent.com/RV_Products_List.aspx?CategoryID=173
https://www.trimlok.com/default.aspx
Also Steele Rubber Products - UsnthedogExplorerMFL. I have replaced the D seals, but I need all the rest. I'm under the impression that the slides must be removed to replace the wipers and seals.
- 2oldmanExplorer III replaced the seals on my big slide. I don't remember the cost. It was a bit tricky getting the fit/clearance just right.
- UsnthedogExplorerI am not an every day watcher. I check my posts closely for a couple of weeks, but then I fall off
- 2oldmanExplorer IIEvery time I've answered this type of question, the OP doesn't respond.
- BarneySNomadI think you will have better response if this post were in the Tech Issues forum where it really belongs. I will move it there.
Barney - MFLNomad IIThere are several types of seals, but I purchased 35' of D-bulb seal for just over $80. I only needed to replace 12' on slide top, but still can replace both sides, when needed.
Don't know what rebuilding you mention, but the seals are easy to replace, as they just slide off/on the wiper channel.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
