420RVfun
May 09, 2016Explorer
Camper Repair-Big Rebuild
Extensive water damage. Roof leaks will be sealed soon, lots of rotten wood. this is an 88 aluminum exterior, stick built interior pull behind camper. After it is all cleaned out I'm thinking about using flex seal on the inside along seams. Any thoughts on this idea? Then installing new wood, that I was going to waterproof somehow, maybe flex seal wood also. And trying to figure out how to make it all strong again, maybe use liquid nails as I rebuild, to help wood stick to frame(aluminum siding was stapled and screwed to wood support structure originally) because I would prefer not to mess with the aluminum exterior, it seems to be in good condition. The leaks I know about are in the roof and around a vent and window. I am replacing floor, walls, and ceiling support structure. Then new siding and interior rebuild. This is my first work on any camper and am looking for some guidance.
