The driver side slide on my 2005 bounder 36e is stuck. After the slide is fully extended it can only be retracted a few inches then stalls. Is there an adjustment to raise the slide over the floor so ...
On our 2005 Excursion, it takes quit a bit of battery power to get over that hump. Make sure the gear underneath is lubed. You should have the engine running when operating the slides.
Try this - crank up the generator, let it run for a couple of minutes and then with it still running see if the slide retracts.
Bill
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
