Jerallen's avatar
Jerallen
Slideout repair- need advice
2003 keystone Cougar. 30BHS
The slide room has one actuator that pushes one side out & the other side is driven via slave tube which is connecten by a pin to the driven side.
The pin broke once and I replaced it with a bolt I had on hand and it worked well util this past weekend when were packing up to leave and it broke again.
The non driven side moves very easily, in fact, I was able to run it back in by hand with channel lock pliers on the tube so we could leave.
My question to any of you that have had a similar problem- should I replace with a split pin OR go with a stronger bolt?
  • Using a grade 8 bolt should locate the problem for you!!!!!!!
  • They are called 'shear pins' for a reason...so that they will break and not cause further damage which using a grade 8 bolt would do.
    Get some new shear pins (split roller pins) to use.
    The shear pin (and the bolt you used) broke because something caused excessive pressure/torque.......broken tooth on drive gear, misalignment, rusted/dirty rails.
    Problem may be at drive side vs slave side.
    Drive side has a driven gear that cross tube attaches to and a drive gear on other side. Either drive gear could have a missing tooth causes a slip/hesitation/momentary jam which breaks the shear pin
    In order to inspect you will need to remove underbelly pan OR just cut a three sided window (leading uncut edge towards front) to gain access.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
