Old-Biscuit
Oct 04, 2013Explorer III
If it is a hydraulic operated slide then you have a solenoid that is leaking back to reservoir (hydraulic pressure keeps them open or closed depending on which side of piston has pressure)
If it is electrically operated then the clutch/brake system is out of adjustment or is worn out.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
