JL7456's avatar
JL7456
Slideout Room Problem
I am having problems retracting our bedroom slide. This has happened twice in the past two months. The first time I was able to "reset" the system by tripping the reset button. The room moved forward a fraction of an inch and then it was able to be moved out as usual.
It is a Kwikee slide and installed on a Winnebago 2005 Voyage. The front slide works fine.
The second time was yesterday after arriving at a campground. After pushing the "out" button nothing happened except the green light flashes "two" times in sequence. I checked the manual for MH and all of the error codes are listed except for two flashes.
I used a paper clip and inserted it in the small hole to reset the system but it did not work this time.
I will try calling Kwikee for their help and then take it to my dealer if that does not work.
Has anyone had a similar problem?
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
