D_E_Bishop
Jan 04, 2019Explorer
lryrob9301 wrote:Lakejumper wrote:
Thanks for the replies. Interesting about the ignition...wouldn't that also affect the starting?.
No, different set of contacts internally in the switch. When the slides start to act up, try cycling the ignition switch off and on a couple of times to see if that fixes the problem. If so, then you need a new ignition switch.
The room extension and the levelers work independent of the ignition. I can extend and retract and level with out the ignition switch turned on. The op should perform a complete battery maintenance before he wastes any money or time.
