valhalla360
May 31, 2022Navigator
MFL wrote:2oldman wrote:
That one generator will be working hard and LOUD running it, and you'll have a heck of a time running anything else, including your converter.
^^This...just not the right tool for the job. If you want to run the air, and other things, better to add/connect second generator, or sell/trade the 2200 and purchase a more capable single.
Jerry
Even if it can run it...so much for it being a quiet generator.
When you see the dB ratings, it's almost always at 25% load, so slightly above idle. A little 2000-2200w generator is running at somewhere around 80-100% of the continuous load rating powering the air/con and even the name brand honda/yamaha units start to sound like a lawnmower.
On the other hand, with a 3000-4000w unit, it's running around 30-50% load and much closer to the dB rating you see in the advertising.
We just replaced a Yamaha 2400 with a Champion 4500. The new generator is substantially quieter with the air/con running (even though the advertised dB ratings are worse) because it barely comes off idle. Yes, it's a little heavier but not drastically.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
