Gdetrailer
Dec 16, 2015Explorer III
BillyW wrote:
Not specifically a RVing question but it does apply to my older tow vehicle. Especially in the winter time, the seatbelts are difficult to pull out and hesitant to retract. I have two older vehicles with this behavior. Do the mechanisms need replacement, or is there a way to lubricate/revive them?
Pretty common problem.. Not an cheap fix..
Depending on the vehicle and year not much can be done without causing damage to them..
Pretty much 2000 and up seat belts can have an explosive charge built in that is supposed to latch the belt quickly in an accident.. Those types definitely are not designed to be serviced.. I wouldn't bother messing with those.
Lazy retraction is often from lint/dirt buildup, I would try a good quality shop vac and see if it pulls any lint/dirt out of the assembly..
Randomly spraying WD40, silicone or any other liquid into the belt mech most likely will just gum it up even worse and possibly damage the seat belt material in the process (you DON'T want to harm the belt material as in weaken it).
The real way to fix is to replace with a new belt unit, not saying I like it BUT that IS the way it is (designed) done or just put up with the lazy belt (I have a 2003 which suffers from the lazy belt syndrome and I just put up with it).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
