MEXICOWANDERER
Nov 11, 2014Explorer
Small Anderson Power Pole Connectors 1, Mex 0
I am fighting the insertion of assembled connector conductor into plastic base, and I shouldn't have to. I am using a standard peg imprint uninsulated terminal (T&B) crimper. After assembly the terminal simply will not slide into the square plastic housing. I've sought out the factory web site instructions, watched You Tube and they make it look easy.
The peg crimper does not leave the terminal mis-shapen but, too fat top to bottom. Simple filing works but without soldering the joint is weaker than a starved cat. I changed crimping tools, no difference. I had to resort to solder to keep any strength to the termination, and the amount of filing needed is exactly the same with or without solder.
Filing is to the top of the barrel, top meaning the bend on the flat tang is facing down. I must be removing 1/16" or better of material and that is flat ridiculous. So is spending an extra fifteen minutes per termination.
I believe the termination is 45 amp rated and I am using 16-20 gauge wire (sometimes paralleled)
I can assemble 10 Weather Pac terminals in the time it takes me to so a single Anderson Power Pole. The problem lies with me and I would like to solve it. I have a lot of connectors to make up.
Thanks
Thanks
