Gundog
Mar 17, 2019Explorer II
Small connector on house battery ??
I am in the process of changing out my house battery bank, I am changing out the battery cables and putting new ends on all the terminals attached to the house battery bank. Most of the terminals are in bad shape.
I have one small set of wires they are very small gauge think phone wire size the wire shield is flat with 5 or 6 different color wires in this flat plastic shield the terminal is falling apart.
I am going to cut the terminal open to check for sure but it looks like all of them are under one connector and attached to a positive terminal of the battery. Does anyone know what this set of wires goes to? Are all the wires in this loom actually connected together and attached to a positive terminal? If I need to I will add a picture of the terminal. I guess I can ohm out the wires since I have cut it off to see if they are connected together.
Thanks Mike
Thanks Mike
