ktmrfs
Nov 10, 2014Explorer III
Mex:
Been there, done that. What I found is that the real genuine connectors that come with the anderson connector work fine. HOWEVER, BE CAREFUL OF ANY AFTERMARKET OR SUBSTITUTE CONTACT. I spent I don't know how much time trying to figure out why some wouldn't insert, just like your going through. best I could tell, dimensions were the same. But they must vary slightly and I couldn't get it to latch. sorted through the connectors, and found the genuine ones works "easy peasy".
I found that I could take a "virgin" aftermarket connector straight out of the package and it would NOT insert and latch, no matter how hard I push, wiggled etc. The genuine article would snap in easily.
I've since done a dry run on any connector. If it snaps in, then it's good and I crimp and solder and they go in fine.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
