DrewE
Mar 13, 2018Explorer III
The generator should work fine, I believe. If you have the charge wizard with a pendant, you can set it to a lower voltage manually for a bit if needed when the batteries are very much discharged...but I suspect that will not be needed at all.
Solar is very nice if it is workable for your situation. A class B may not have much open space on the roof for panels nor ready storage for portable ones. Solar is also much less effective if one camps in wooded areas or at northern latitudes during the winter.
