sdetweil
Apr 02, 2015Explorer
Boxer Lovers wrote:
How much p.s.I. can it produce? My Triglide needs up to 95 p.s.I. to come to level. I have to use a 150 p.s.i. pancake compressor to inflate. Small compressor will allow pressure to escape the air bag.
the compressor supports 100psi.. and that is the max on the triglide too.
the valve will maintain the pressure, not the compressor,
altho the compressor also has a check valve, so air is one way.
I also have onboard air tank on my truck, run hose from there normally when I climb in the bed to adjust the hitch.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
