christopherglen
Apr 02, 2015Explorer
I ran truck airbrake tubing from the pinbox to the side storage compartment. I have a Viair with a 0.5 gallon tank there. And manual valves to fill and dump the pinbox. The Viair is on a 140 psi pressure switch, and has an air fitting for extension airlines / tools. I use it to fill tires as well.
I replaces the Schrader valve on the airbag with a Tee fitting, put the factory Schrader on the front (as a manual fill if the compressor dies) and the airbrake line off the rear.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
