alank2's avatar
alank2
Small engine question
Since you guys know tons of stuff I figured perhaps a question about my Echo blower would be something you guys would know. It is a 2 cycle engine and I can get it started, but it acts like it is starving for fuel. It will run slowly, but if you try to give it more throttle, it will stall out. The other thing that is odd is that the bulb you use to prime the carb will let you press it, but it doesn't come back out easily like it used to. Could it be a fuel filter that needs replacement? It seems like those are often the culprit...
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 21, 2025
