MrWizard
Feb 05, 2017Moderator
vector KAW test
20 amp settting
display says 21.2 amps charge
532 VA
337 watt
4.36 amps
0.63 PF
122 vac
might be close, but i think it will do the job
IF it has an Econ switch, turn that off
Barry
no need to wait on your test
you have a 44amp drain
and only 20 amp charge from the vector
still a 24 amp net loss
you can fire it up right now to see if it will maintain the 20amps vector use and stay running
after that, you can do a recharge time test, when ever you want
20 amp settting
532 VA
337 watt
4.36 amps
0.63 PF
122 vac
Barry
