SoundGuy
Feb 07, 2017Explorer
BFL13 wrote:
It runs ok and powers the 35 amp Vector 1092A at 20 amp setting and also the bigger VEC1093DBD at 20 amp setting. For some reason that 35 amper does only 18.2 at the 20. The 1093 does 21.0 at its 20.
It conked out when I went up to 35 amps on the 1092A, as expected. I forget if it was the circuit breaker or the engine. Anyway, easy restart.
I'm heading over to PA this morning to take a look as I'm curious as to how small this little genset may be or whether it's not much different in size, as it is in weight, to a 1000 watt Honda or Yamaha. You've tested yours at 20 amps but do you have the means to tick that up a bit to 25 / 26 amps @ 14.4 volts and tell me if it still can handle that load? I'm curious because that's what I'd be doing with a CTEK Multi US 25000 or NOCO G26000 ... that's about 375 watts but I'm thinking a PF of ~ .58 would put the VA way over the limits of what this little genset can do.
