westend
Dec 12, 2016Explorer
That's not typical of most small engines. Likely culprit is a crankcase gasket. You might get lucky and are able to tighten the bolts on the bottom of the engine to reseal the gasket but probabilities of that are low.
Two solutions come to mind: Either consider it a self-draining oil system where half the change is done for you, only needing to add oil whenever in use or pull the engine out, remove the lower part of the crankcase, install new gasket, and attach base again.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
