mkirsch
Dec 13, 2016Nomad II
The "obvious fix" is to identify the source of the leak, determine the reason for the leak, and repair it. Since it could be leaking from any of a dozen places for 100 different reasons, you can't get more obvious than that.
Most likely any seals are standard size, and can be obtained from NAPA or a local seal and bearing supplier. Fuelproof silicone gasket maker was probably used to assemble the engine, so that's all you need for gaskets.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
