I have a small leak in the skylight over my shower. I got up on the roof today and sprayed around the skylight with clear Flex Seal. I know it's a little late to be asking as I've already used it, ...
I agree with robsouth. Temp fix at best. Since winter is coming and even northern CA may not have the best weather for repairs I would try to keep it covered and clean it up in the spring and use Dicor leveling caulk around the area. May want to check the whole roof.
Dicor has leveling caulk for horizontal surfaces and vertical caulk for vertical surfaces.
