I helped a buddy install a 200A service on a camping lot he bought. I also wired in the classic "100A" RV panel with 50/30/20A outlets. (all to code, permitted and inspected) Here's the rub, since ...
Is 7 kW really not enough? I would ignore the restriction and live normal. Deal with the issue if it actually festers into something. Otherwise they can replace the transformer.
If this is a 50 amp RV check that the loads are balanced. Such as if he has two A/Cs check that one is on each side of the panel in the RV.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
