ScottG's avatar
ScottG
Nomad
Mar 29, 2018
Smart meter?
I helped a buddy install a 200A service on a camping lot he bought. I also wired in the classic "100A" RV panel with 50/30/20A outlets. (all to code, permitted and inspected)
Here's the rub, since this was only a camping site and the closest transformer is close to being overloaded (according to power co), the electric co. has "limited" our feed to 7000 watts max load. Oddly, they had no problem with us running that 7K to a 200A panel.
Right now the voltage is great even when we're running both our RV's with three AC's off it. I have read some things suggesting the meter will do something if draw too much.
I know what a SM is. My question is, since it is metered by a Smart Meter, what happens if we exceed 7KW?
  • You need to ask the PoCo how they would handle that....SM's can't throttle voltage or create brownouts. In S&B homes large draw appliances like a/c and water heater can be fitted with relays so the PoCo can shut them down during peak demand.
    In your case I would think the 2 options are to shut your power off, or raise the kWh rate when you exceed the limit. 7000w is only about 60a, so with 3 a/c's going and maybe a HW heater or microwave, you are almost there.
    Interesting article about smart meter's in the PNW.
    FWIW, those pole transformers are like roman candles when they blow, hope it's far enough down the road where it can't get your rubber roof....
  • TenOC wrote:
    Is it a demand type meter in which the power company will charge you extra if you exceed the demand they set?
    They never said anything about that and I don't *think* the bill is structured to show that but I will ask my buddy about it.
    Thanks,
    Scott
  • Is it a demand type meter in which the power company will charge you extra if you exceed the demand they set?
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 28, 2025
