So, did a through check with a propane gas sniffer….no propane leaks any where (as I suspected). So I did what I did on the previous TC I used metal duct tap on the entire seal of the outer decorative frame and the water heater. Even though the water heater itself has a outer flange that should be backed by butyl tape I took no chances. I have tested it twice, not at altitude but in some wind (which would also cause it to smell) and no smell.
I also plan on swapping out the gas oriface to the high altitude #65. This will rob some of the BTU’s at lower elevations but still work just fine. No sooting. I will be on the coast of OR for a few weeks, so I will report how it did there.
