joebedford
May 18, 2013Nomad III
My WFCO converter died 1 week before the end of the two-year warranty. They replaced it under warranty. I installed it - no biggy.
Your reefer needs 12V to run so it's probably not toast.
Your converter probably failed a while ago and so your battery is dead. Or the battery is no good and you didn't know it.
I ran my rig on a 15A battery charger for two weeks until I was able to install the new converter. Just had to be careful about how many lights I turned on.
No sure why your 37" TV isn't working - it probably doesn't use 12V. Make sure you check all breakers and fuses.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
